Need to Lock CUC users VM using BAT
shaijal.allipra
There are many unused VM users in Unity connection, I need to lock their Voicemail profile using BAT. Manual option is under Users-> Edit Password Settings->Locked by Administrator
I have created a user template and then tick the option 'Locked by Administrator' and did a BAT update, BAT was successful, but it didn’t update in the user profile.
Is there any way to update this option using BAT in CUC.
version 11.5
shaijal.allipra
I found a way to do this.
1- Create a simple CSV file with 'Alias' and add the user Alias you wanted to update
2- Users -> Bulk Edit By CSV ->Edit-> Locked by Administrator -> There are two
check box click both -> Submit
