Not able to access MCS 7816 6.0
sudeesh12
Hi all,
when I access the Media Convergence server through browser,I can access its "OS Administration" with the configured username and password,It does not take the username and password for the"CM Administration,Serviceability & Disaster Recovery system" options
Anybody has the solution !
Sudeesh
Jaime Valencia
are you using the username / pwd you created during the install or another user to which you granted access??
are the DRF services running??
javalenc
if this helps, please rate
java
Hi javalenc,
Yes , I am using the same username/password I created during Installation
DRF services are not running
Sudeesh
try starting them and then try again
javalenc
java
