02-17-2010 07:53 PM
Appreciate any clue...
- CCME cluster site call to CME site via MPLS not able to hear from CCME cluster site. but able to hear from CME site.
- CME site call to CCME Cluster site working fine
what is possible issue?
02-23-2010 02:58 PM
Whenever I found a one-way voice issue on an IPT system, it was due to a problem with IP routing. Check that you have IP connectivity between the endpoints you're having issues with by launching a customized ping with source and destination addresses configured to be the same as the ip phones that are trying to talk to each other.
Cheers,
Jose
04-05-2010 08:08 PM
Hi bro,
Same with mine ..one way audio ..every time call from CUCM to CME but CME to CUCM is fworking fine. what is this debug mean?
voip_rtp_update_callinfo: ERROR - gccb not found
voip_rtcp_stop_session: ERROR - Dest IP Addr=0, no RTCP pkt sent
voip_rtp_exchange_context_info gccb not found, context is NULL
voip_rtp_xmit:no context
N
04-06-2010 11:57 AM
I had the same problem with calls between a CUCM-BE system and a remote CME system. I actually had two issues. One was the one-way audio which was corrected via a routing fix. The other had to do with voicemail. If you tried to leave a voicemail on the remote CME, it didn't work. This turned out to be a codec issue. We had G.729 set up between the CME and the CUCM-BE. Unity Express requires G.711. Once we fixed that and the routing issue everything worked great. Hope this help.
04-07-2010 06:35 PM
Thanks, but not everyone from CUCM site .. a few random user only.
Today got another error..
Apr 7 02:11:20.134: //37037/AFA7E3138F25/CCAPI/ccCheckClipClir:
In: Calling Number=3918(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Out: Calling Number=3918(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Apr 7 02:11:20.134: //-1/AFA7E3138F25/RXRULE/regxrule_dp_translate: No profile found in peer 26 for outgoing direction
Apr 8 01:50:49.020: voip_rtp_xmit:no context
Apr 8 01:50:49.040: voip_rtp_xmit:no context
Apr 8 01:50:49.060: voip_rtp_xmit:no context
Apr 8 01:50:49.084: voip_rtp_xmit:no context
Apr 8 01:50:49.100: voip_rtp_xmit:no context
Apr 8 01:50:49.120: voip_rtp_xmit:no context
Apr 8 01:50:49.144: voip_rtp_xmit:no context
04-07-2010 11:52 PM
Not being an expert in decoding traces, I do recommend that at this point you go ahead and open a TAC case. They can help you reviewing the configuration of the CME in detail and also analyzing the traces for error messages, something that goes beyond the purpose of this forum.
Cheers,
Jose
12-24-2013 04:58 AM
Were you able to find a solution or meaning to the error above. I am seeing similar errors in a lab environment. I am getting no audio between PSTN and HQ via PRI. HQ is using SIP to CUCM.
Mar 1 01:39:05.727: voip_rtp_xmit:no context
Mar 1 01:39:05.747: voip_rtp_xmit:no context
Mar 1 01:39:05.767: voip_rtp_xmit:no context
Mar 1 01:39:05.787: voip_rtp_xmit:no context
Mar 1 01:39:05.807: voip_rtp_xmit:no context
Mar 1 01:39:05.827: voip_rtp_xmit:no context
12-25-2013 07:13 AM
I think is due of codecs mismatch
BR
Envoyé de mon iPhone
Le 24 déc. 2013 à 13:57, "elvinmorales" <community@cisco.com> a écrit :
Cisco Communities
One way Audio CCME cluster to CME
reply from elvinmorales in Technology > Collaboration > Unified Communications - View the full discussion
Reply to this message by replying to this email, or go to the message on Cisco Communities
Start a new discussion in Technology > Collaboration > Unified Communications by email or at Cisco Communities
Following Technology > Collaboration > Unified Communications in these streams: Email Watches
