01-19-2010 07:45 AM - edited 03-19-2019 12:18 AM
I call from our main site to phone assigned to new VLAN ,Remote site phone can hear us but we can't hear them and issue remains the same when call is initiated from remote site to phone's on other VLAN's or sites.
At remote site I installed another phone and assisgned the switchport to new voice vlan then both new phones can communicate to each other but same issue in communication to phones on other vlans / locations
I have checked all the access-lists and FWSM but couldn't see any issues ....ANY IDEA what's causing one way communication issue cos previous team changed the IP addresses on our main site but no such one way communication issue. Interesting thing is that I picked one of the free subnet from Main site IP address planning structure and implemented at remote site and had no issues with communication at all
Solved! Go to Solution.
01-19-2010 08:30 AM
You can do a simple test:
1) Make a test call and make sure the call is connected
2) While the call is connected (and you got one-way audio), press the question mark (?) button twice on the phone. It'll show you the realtime statistics of transmitting packets and receving packets.
3) Do the same thing on the other phone.
4) Compare the statistics on both sides, you should be able to tell which phone was sending packets, which phone was not receiving it.
If one side is sending packets, the other side is not receiving it, get a network engineer to trace the path.
Michael
01-19-2010 08:30 AM
Michael
01-19-2010 10:07 PM
Hi Michael,
Thanks for help - I have managed to resolve the issue - Test phones we used at the Main site which had issue hearing the caller from remote site had some access-list applied to it's Vlan interface (SVI) and we also found assymetric routing which was causing outbound packet to go out the other path hence another access-list had to be mofied for the time being untill some route maps can be defined to make sure the correct packet flow path.
Now, one issue is left - PSTN user from outside when calls remote site phone - Remote site answers the phone can hear the caller but PSTN caller can't hear the remote site user. Previously we were using public address - Now we are using Private IP's - I will start looking in to the access-lists but is there any NAT issue to be taken care of.
Looking forward to your response and thanks again for your impressive answer earlier..(I had no clue about ? button - learning new technology the hard way)
