phone firmware compatibility between CUCM 8.6.1 and 10.5.1
HUI YI CHEN
Hi Guys,
We are planning to upgrade CUCM from 8.6.1 to 10.5.1(virtual to virtual). I'm trying to check the phone support and compabilitiy of phone firmware since we have a very big and various model.  My concern is
1) are all those model supported by 10.5?
2) We are going to upgrade phone firmware first before the cluster upgrade,which mean after phone firmware upgrade, the phone will  still register with old cluster 8.6.1 for some time. Does the new phone firmware is compatible with old cluster 8.6.1?  I couldn't find the full list for all the phone model we are currently using, especially 6901,6911,7911,7912,7921,7925,7937,7960 and 7961.
Model
6901
6911
6921
6941
7911
7912
7921
7925
7937
7941
7942
7945
7960
7961
7962
7965
7975
8941
8945
8961
9951
9971
5 Replies 5
Aman Soi
hi,
you can refer the link
http://tools.cisco.com/ITDIT/vtgsca/VTGServlet
regds,
aman
Hi Aman,
thanks for the prompt reply.
I checked that linke before but i couldn't find all the phone model in the link.
such as 7911,7912,7921,7925,7937.
Are those phones still supported by CUCM 10.5? what' the firmware for them in 10.5 if supported.
Hi Chen,
these IP phone models are very much supported.
You can have latest FW deployed for these models.
For 7911: 9-3-1SR4-1S
7921:1.4.5.3
7925:1.4.5.3
7937:1-4-4-0
regds,
aman
Thanks Aman.
since we are going to upgrade phone firmware before cluster. will the latest firmware you mentioned above be compatible with old cluster 8.6.1?
yes...
regds,
aman
