03-27-2016 11:07 PM - edited 03-19-2019 10:54 AM
Hi all,
CUCM version is 9.1.2
The web gui to phone sets are not reachable on our Cluster 2 .
When I try to access to web interface of any type of phone( 8941 or 6941 etc) , browsers (Chrome or internet explorer) says waiting for reply but no luck.
I checked the web access on phone management and it's enabled
Any comments are appreciated.
Thx.
PS: I did a telnet to phone IP adress with port 80 and it's successful.
03-27-2016 11:21 PM
Can you try restarting the TFTP service and reset these phones and see if this helps.
Try swapping a working and a non-working phone as well.
Please post the results of the same.
Manish
03-28-2016 12:08 AM
Hi Manish
I restarted the TFTP service ( all of the TFTP servers in cluster) And resetted the 2 of the phone set.
Still same.
Btw all phone sets are facing the same issue. None of them's web interface is working. So there is no swapping operation..
03-28-2016 03:32 AM
Can you delete the ITL/CTL on one of the phones and test, if it still does not work then you need packet captures when trying to access web page.
Manish
