08-19-2018 10:33 AM
ISR4321/K9 router with NIM-1MFT-T1/E1 module, isr4300-universalk9.16.06.02.SPA.bin software,
configured for Euro ISDN connection to PSTN provider, did not connect to PSTN after power outage.
Investigation shows, that the following commands are missing from running-config:
pri-group timeslots 1-31
interface Serial0/1/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn incoming-voice voice
voice-port 0/1/0:15
Connection to PSTN can be restored by the following configuration commands:
controller E1 0/1/0
According to my information the E1 line from PSTN provider was probably down for some time after the gateway was up.
It is the same as if the gateway is restarted with the ISDN/PRI E1 line disconnected.
Do you know how to configure the E1 controller to start the E1 trunk after controller reload under such conditions?
Solved! Go to Solution.
09-29-2018 12:08 PM
The issue is solved now with TAC help, ticket SR 685130611.
Issue was caused using incorrect codec complexity:
voice-card 0/1
codec complexity medium
controller E1 0/1/0
clock source line primary
And during router reload an error was output to console:
E1 0/1/0: No voice port or DSP resource for voice feature
E1 0/1/0: For MFT T1E1 modules, pri-group has to have DSP (PVDM4) modules installed.
E1 0/1/0: Please check if DSP module is plugged in before configuring pri-group!
E1 0/1/0: This pri-group configuration is REJECTED!
%No configuration will be applied
% Invalid input detected at '^' marker.
voice-port 0/1/0:15
When using codec complexity flex, router reloads OK.
08-20-2018 06:11 AM
Sounds like a write mem was never done on the router.
08-20-2018 02:21 PM
08-20-2018 02:23 PM
09-29-2018 12:08 PM
voice-card 0/1
controller E1 0/1/0
voice-port 0/1/0:15
