03-18-2013 01:40 AM - edited 03-19-2019 06:26 AM
Hi all,
we just updated our Unified Communication Manager to version 9.1.1.2000-5, because of the possibility to use Dial via office (DVO).
I followed the learning video in the supportforum:
https://supportforums.cisco.com/videos/5549
But when I`m adding the Associated Mobility Identity (from an IPHONE or Android) and wants to add the "mobility Profile" to it, I get the following error:
Update failed. Mobile Smart Client is required for a Mobility Profile
I don`t found anything in the Mobility Profile which I can add.
Thanks in advance
Frank
06-02-2013 04:46 PM
If you havent discovered this already, you need to download the iPhone and Android ISO's to upload to the CUCM even if you are running version 9.1.1.
Chad
06-05-2013 10:46 PM
Hi Chap,
thanks for the answer.
What do you mean? The COP Files??
This I already have done.
T&R
Frank
10-02-2013 01:02 AM
I have the same issue, and I also have all relevant cop files installed:
admin:show version active
Active Master Version: 9.1.2.10000-28
Active Version Installed Software Options:
dp-ffr.3-1-6.NL.cop
cmterm-9951.9-2-4-19.cop
cm-locale-en_GB-8.6.2.1000-1.cop
cmterm-iphone-install-130417.cop (Jabber 9.5 beta cop file)
cmterm-iphone-install-111019.cop
cmterm-android_9.1.1v1.cop
cmterm-bfcp-e.8-6-2.cop
cmterm-cupc-dialrule-wizard-0.1.cop
cmterm-69xx-sccp.9-2-4-3.cop
ciscocm.free_im_v1.0.cop
cmterm-android_9.5.1v5.cop
cm-locale-nl_NL-9.0.1.1000-1.cop
cmterm-android_8.6.2v17.cop
cmterm-894x-sccp.9-2-3-5.cop
cmterm-jabbertablet-100v10-dm.cop
cmterm-iphone-install-130129.cop
uc-locale-nl_NL-9.1.0.1-32.cop
Any clue?
10-02-2013 02:19 AM
I found the solution: You have to enable "Enable Csico Unified Mobile Communicator" on the TCT Phone in CUCM.
12-17-2013 02:21 PM
I had the same problem also.
Ruud van Strijp is correct. You have to enable Cisco Unified Mobile Communicator on the BOT or TCT device. This worked for me.
