Problem with Jabber-Login using LDAP-Authentication
the1
i'm using CUCM v. 9.1.2.12901-3 and CUCM IM & P v.9.1.1.51900-5.
i have activated LDAP-Synchronisation and Authentication with CUCM and a Microsoft AD. I can see the synced Users under the Point "End Users" in CUCM.
  • Login to /ucmuser - Successful
  • Login to /cupuser - fail
  • Login to Jabber for Windows Client - fail
After creating a local End-User in CUCM with Presence enabled Feature and automatic syncing through CUCM IM & P-Server it is possible to login in in Jabber-Client.
I cant find the solution.  please help
chris
keglass
Level 7
Level 7
Chris,
I'm sorry to learn you are having problems with your CUCM and Jabber client. I recommend you also post this to the Cisco Support Community for additional feedback and information.
Hope this helps.
Kelli Glass
Moderator for Cisco Customer Communities
