Probleme with the caller input in CUC 8.5
aminedahel
Hi, guys,
I have an issue on CUC 8.5, knowing that I'm working on CUCM 8.5 as well.
I'm trying to configure the caller input for a user in a way that when someone call this user and reach voicemail, he will press 1 to reach the extension XXXX, in case of no answer from XXXX extension, the call will be forwarded to YYYY.
I really appreciate your help, guys,
thanks in advance.
Jaime Valencia
Configure a CH with transfer settings to XXXX, set that as caller input 1, attempt transfer to.
On phone XXXX set the call forward options to YYYY.
java
if this helps, please rate
Jaime Valencia
java
Thank you, Jaime, for the precious hint.
