Problems with CUCM7 and AXL
kamil_folga
Hi!
We are trying to connect to CUCM 7 with AXL to retrieve data about users. Issue the query:
java  -cp classes;.\lib\saaj-api.jar;.\lib\saaj-impl.jar;.\lib\mail.jar;.\lib\activation.jar;.\lib\jaxm-api.jar;.\lib\jaxm-runtime.jar;.\lib\xercesImpl.jar;.\lib\xml-apis.jar  AxlSqlToolkit -username=xxxxx -password=xxxxx -host=10.11.200.10  -input=sample.xml -output=response.xml
We get the following response:
select * from  callmanager
Sending  message...
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/"><SOAP-ENV:Header/><SOAP-ENV:Body><executeSQLQuery sequence="1340019422168"><sql>select  *  from callmanager</sql></executeSQLQuery></SOAP-ENV:Body></SOAP-ENV:Envelope>
2012-06-18  13:37:02
com.sun.xml.internal.messaging.saaj.client.p2p.HttpSOAPConne
ction  post
SEVERE: SAAJ0008: Bad Response; Not  Found
com.sun.xml.internal.messaging.saaj.SOAPExceptionImpl:
aging.saaj.SOAPExceptionImpl:  Bad response: (404Not Found
         at
com.sun.xml.internal.messaging.saaj.client.p2p.HttpSOAPConnection.cal
l(Unknown  Source)
        at  AxlSqlToolkit.sendMessage(AxlSqlToolkit.java:138)
        at  AxlSqlToolkit.execute(AxlSqlToolkit.java:199)
        at  AxlSqlToolkit.main(AxlSqlToolkit.java:244)
Caused by:  com.sun.xml.internal.messaging.saaj.SOAPExceptionImpl:  Bad
response:
(404Not Found
         at
com.sun.xml.internal.messaging.saaj.client.p2p.HttpSOAPConnection.pos
t(Unknown  Source)
        ... 4 more
What can cause errors in the answers?
Greetings,
Kamil
Aaron Harrison
Have you enabled the AXL service (through serviceability/service activation) on the 10.11.200.10 server?
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Yes, AXL works.
Kamil
Well - a 404 means 'page not found' typically, so either the AXL service has not been enabled on that server, is not working for some reason, or the user you specified doesn't have AXL rights.
I would check your user rights, and if they're OK try a different CUCM server (enabling AXL if necessary).
Aaron
