08-13-2019 06:37 AM
First of all, thanks in advance for dealing with my relative new-ish knowledge of the Cisco systems. Yesterday working with Cisco support, they helped with a replication relationship rebuild with our servers here. For the record we are using CUCM Version 10.5.2.11900-3 if that helps. We had a few issues prior to this rebuild, namely that of devices not displaying the correct display name, even when changed in the CUCM. I recently added a phone, and while it pulls an IP, its registration is rejected in the CUCM.
Prior to this issue occurring, we had an issue in our server room with the HVAC unit, and the servers were shut down gracefully. After restarting the servers, a recovery disk ended up needing to be used on the server to get the VMWare back up and running. While it appears that the two servers to check CUCM show the same data, and are in sync
Solved! Go to Solution.
08-19-2019 05:31 PM
08-13-2019 10:42 AM
Rick,
Let's go over one issue at a time. What is the model of the phone that is being rejected? Can you attach screen shots of the phone configuration page and the directory number configuration page. Top and bottom of the directory number configuration page and top of the phone configuration page.
Jason
08-13-2019 06:10 PM
08-15-2019 06:44 AM
08-15-2019 08:30 AM
Maybe try a factory reset just as a test, to clear everything out of that phone.
08-15-2019 09:42 AM
08-15-2019 10:39 AM
08-16-2019 05:41 AM
08-16-2019 12:17 PM
08-16-2019 12:28 PM
08-19-2019 10:52 AM
08-19-2019 05:31 PM
08-20-2019 10:26 AM
And the resolution: The TFTP Server Service was not running on the CUCM. After re-starting it, deleting and re-adding the phones, all the phones in question now are registered and working properly.
