Beginner
RCC using CUPS error when Intercom button is assigned to phone
We are currently running CUPS version 6, CUCM version 6.1.3 with MOC 2007 and have discovered that remote call control always activates the Intercom button as opposed to the actual line number when an intercom button is added to a phone.  Has anyone else experienced this or know of a fix.  We have 2 offices that heavily utilize the intercom button and click to call from contacts is no longer an option for them.
I understand CUCIMOC does not have this problem but we don't have the money to purchase clients.  We are looking to upgrade shortly to CUCM 7.1 and CUPS 7 as well.  Not sure if a fix is found in those versions either.
Loz
Everyone's tags (2)
1 ACCEPTED SOLUTION
Highlighted
Engager
Re: RCC using CUPS error when Intercom button is assigned to pho
I guess you didn't specify the partition in the line URI?  (in Active Directory)
The format is as below:
tel:xxxx;phone-context=dialstring;device=SEP0002FD3BB5C5;partition=myPartition
See URL below for more details:
http://docwiki.cisco.com/wiki/Cisco_Unified_Presence%2C_Release_7.x_--_How_to_Configure_Microsoft_Components_for_integration_with_Cisco_Unified_Presence#Line_URI_Configuration_on_Microsoft_Active_Directory
Michael
http://htluo.blogspot.com
Highlighted
Engager
Michael
Beginner
Thank you, that worked like a charm!
Liz
Enthusiast
Hi htluo,
did you tested with extension mobility user profile ?
currently Im on test RCC+Extention Mobility w/ Intercom.
on debugging presence there are info : "user  has multiple lines, but has yet selected one" and FAIL AUTHORIZED
Do you know how to fix this once ?
Rahman Dani
Ask the Expert- Webex Hybrid Services Solutions
