Running NME-CUE on ISR G2 (2921) with SM-NM-ADPTR
BRIAN SEKLECKI
All:
   I'm hoping to hear success stories from anyone running NME-CUE with an SM-NM-ADPTR in the ISR G2 Series.
Also, which versions of CUE are you running? 8.6.7 seems to be the latest "NMX" build.
(NOTE: I know the NM-CUE and ISR G2 are both E.O.S., and SM-SRE-{7xx,9xx} is a better pick for the ISR G2 anyway, but I'm looking to build a cost-effective replacement for the Cisco UC520)
~BAS
0 Replies 0
