12-17-2020 05:35 AM
Hi Good People,
Please help me to solve my problem. I have a CUBE that works fine for Voice traffic, and now I'm configuring the T38 protocol to enable the fax service. The problem is FAX can only send/receive faxes if the others are running on SIP too. But if a different side is running on E1, the fax will not work.
I've gathered the debug output from CUBE, but still don't understand what's going on.
The call flow is: ITSP <--> SIP <--> CUBE <--> CUCM <--> MGCP <--> VG224 <--> FAX Machines.
Thanks in advance.
Solved! Go to Solution.
03-24-2021 11:18 PM
The problem was solved. I tried to uncheck the MTP option on the CUCM SIP Trunk. And some things have been adjusted on the ITSP side such as Codecs, etc.
12-17-2020 06:51 AM
SIP message may instruct that following threshold in the configuration
12-17-2020 07:01 AM
Thank you for your comment, would you like to provide an appropriate reference for your comment?
12-17-2020 06:54 AM
rules for message communication and sampling for channel information.
T.38 - Delay<1000ms, Jitter<300ms, Packet loss should be NONE unless T.38 with redundancy.
Passthrough - Delay<1000ms, Jitter<30ms, Packet loss should be NONE.
Protocol Based switchover - This is standard based.
NSE Based switchover - This is proprietary and works only between Cisco voice gateways.
12-17-2020 06:55 AM
Message communication between differant devices.
12-18-2020 03:50 AM
Can find the referance SIP communication message between the devices(FAX)
12-18-2020 03:55 AM
Debug message useful referaance to capture SIP message troubleshoot issue
12-18-2020 04:16 AM
This are different messages communicate between the devises.
12-18-2020 05:26 AM
GW and CUCM message communication frequency message communication when debug this info
12-20-2020 08:35 PM
I've tried this, but it still doesn't solve my problem
03-24-2021 11:18 PM
