SIP Normalization for oubound calls on SIP trunk
devraj123
Hi All,
I need to modify this script to change this header
From
Remote-Party-ID  "Test" ;party=calling;screen=yes;privacy=off
To
Remote-Party-ID  "Test" ;party=calling;screen=yes;privacy=full
Please confirm if below script is ok:
M = {}
function M.outbound_INVITE(msg)
local fromtag = msg:getHeaderValueParameter("From", "tag")
local pai = msg:getHeader("P-Asserted-Identity")
local uri = string.match(pai, "(<sip:%+8820.+>)")
local uri2 = string.match(pai, "(<sip:%+881995.+>)")
                if uri or uri2
                then
                                msg:modifyHeader("From", "Anonymous <sip:anonymous@anonymous.invalid>")
                                msg:addHeaderValueParameter("From", "tag", fromtag)
                                msg:addHeader("Privacy", "id")
                end
end
return M
Please assist.
Devraj
nikhilrajan
Hi Devraj,
Even i would like to change the Privacy to full.
Were you able to find the answer?
Nikhil
