224
Anju Josua
Beginner
SIP SP IP Requirement for CUBE HA
Hi all,
currently i am planning to do CUBE redundancy with HA.
i've read this documentation:
https://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-border-element/112095-cube-hsrp-config-00.html
On that documentation, 2 CUBE connect to 1 SIP SP (i attached the picture).
my query, then I need 3 ip address from SIP SP right?
because usually in my country, SIP SP only provide ip address with /30 subnet. 1 ip for the SIP SP then 1 ip for me (customer).
but for this kind of scenario, in my understanding then we need at least /29 subnet from SIP SP. Because I need 3 ip address then 1 ip address for SIP SP.
please someone kindly help to clarify my query.
Josua
1 REPLY 1
Roger Kallberg
VIP Mentor
Yes I do believe you would need to have 3 IP addresses on your side for HSRP. So a total of 4 IPs would at a minimum be required on your link network to the ITSP. Are the SP using public or private IPs on the link network?
Response Signature
Create
Recognize Your Peers
Content for Community-Ad
