03-20-2015 03:33 AM - edited 03-19-2019 09:21 AM
Hello, guys!
As you all know, providing management and provision for speed dials and BLFs on UC phones with expansion modules (like 7915/7916) is a huge pain in the ass, if we talk about enterprise environment. Sure, such great instrument as Bulk Administration Tool helps a bit, but i'm curious, if there exists other software products(like third-party) or instruments, which can provide usable and robust management/monitoring for speed dial buttons?
Or, if you can, please share your experience or thoughts in dealing with speed dial management.
03-20-2015 03:51 AM
Putting this sort of application together isn't so hard, especially for something fairly simple like this.
What would you want it to do exactly? If you could have your 'ideal' piece of software?
Aaron
03-20-2015 06:12 AM
Hi, Aaron
The main goal of this "ideal tool" is, i assume, to perform monitoring for speed dials on phones and check, if there is a particular DN to a corresponding SD. This kind of monitoring will eliminate situation, when DN was deleted, but SD, which points to this DN, is still persist on some phone.
Alexander
