UC500 call routing
m.elmaaroufi
Hi all,
I have UC500 configured to do calls with both SIP user agent and FXO, for outbound calls, my request is how can i route calls to mobile destination via FXO, and Fixe destination via SIP user agent
thanks in advance
Med
You can use the destination-pattern on your outgoing dial peers to choose which dial peer to use.
If you do not know the number of the 'mobile destination', you will not be able to do this. But, if there is a range of numbers, you can make the destination pattern something like this:
dial-peer voice 1 voip
destination-pattern [5-8]...9....
That would be any 9 digit number starting with 5 through 8 with the 5th number being a 9.
hth,
nick
