03-29-2013 07:10 AM - edited 03-19-2019 06:30 AM
Hi ,
I want to upgrade from 8.0 to 8.6 Unity Connection. But do I need license? e.q (ucss , esw)
Does anyone know if you need product codes?
Thanks.
03-29-2013 07:42 AM
You will not need to apply any new licenses during the upgrade. Though you should request the media upgrade via PUT portal for official tracking which means you need to have active UCSS/ESW.
HTH,
Chris
04-01-2013 08:07 AM
Dear Support,
We have upgrade cucm version 9.1.1 and install Cisco Unity connection 8.6 .
Does we need to upgrade cisco unity connection ver 9.1.1 to avoid any comptibility issue or no need to upgrade . its ok with ver 8.6 or not
Please advice.
regards
Syed
04-01-2013 08:11 AM
Syed,
You do not need to upgrade Unity Connection, it is fully supported with these versions, though for consistency I would definitely recommend it.
HTH,
Chris
04-16-2013 01:46 PM
Hi chris,
Thanks for your information, i would like to configure cisco unified messaging by using cisco unity connection 8.6.2 and cucum 9.1.1 so that i get the voice mail on outlook 2010 as we exhange server 2010.
Also LDAP intergration with cisco unity connection 8.6.2
So please provide the steps for the configuration because cisco doc huge data to read . if simple steps highly appreciate or else any videos .
Syed
04-16-2013 07:50 PM
Syed,
You will receive better response if you open new discussion on new topic and rate previously answered question. As to your specific questions have you tried searching the forum for answers as these are very commonly asked and answered questions.
HTH, please rate all useful posts!
Chris
