10-27-2009 09:23 AM - edited 03-18-2019 11:54 PM
Hi, I am trying to find out if there is a way to change the "FROM" address for voice messages delivered to users via Unity. Currently the From address is "Unity Messaging System - SERVER NAME". I would like to be able to remove the server name from displaying. I found where the subject line can be customized, but i cannot locate where the FROM address could be changed.
Solved! Go to Solution.
10-27-2009 11:08 AM
You can't change it from the Unity side - the message is sent from that account (required to have a sender in Exchange land). You can change the display name for that user (which is created with the server name by default). Just don't delete the account (it'll get recreated on the fly). But you can change the display name to remove the server name from it and the "from" field for messages from outside callers will no longer show the server name.
10-27-2009 11:08 AM
