05-01-2011 04:25 PM - edited 03-19-2019 02:51 AM
Unity Connection 8.5(1)SU1
I have a single integration to CallManager with a two-server Unity Connection Cluster. I'm licensed for 300 Voicemail Ports (LicVoicePortsMax) My plan was 150 ports on CU Publisher and 150 ports on CU Subscirber using SIP trunk. I had no problems with the CU Publisher..
I setup in CUAdmin > Telephony Integrations > Port Groups with 150 in PortGroup1 with CU Publisher.
The second PortGrup2 with CU Subscriber only creates 100 ports with "Unable to Create Ports" "Maximum number of telephony ports in system is exceeded" even though under Licensing I see 150 free Voicemail Ports before I started. In some cases if I delete the ports and start over again the number of ports it creates seems to vary.
Bug?
05-02-2011 05:36 AM
Hi Jason,
Although this Bug does look somewhat similar to your issue, I'm guessing that you may be missing
the ports on your second License (that is tied to the Subscriber MAC). Can you post up your two licenses
Cheers!
Rob
05-02-2011 07:58 AM
Answer: I forgot under Licensing there is a Drop Down box to pick the Unity Connection Subscriber server. Port are l
icensed per server. Once I added the HA license to the Unity Connection Subscriber and
hit the drop down box for the subscriber I could see the voicemail ports on the Subscriber.
05-09-2011 04:43 PM
Installed high availability license on Subscriber. Web Inbox was getting
stuck on loading, unchecked the option subscriber has to change the password
at next login.
