Unity Connection 8.5 Call Handler after greeting.
Michelle Awtrey
Where can you change the seconds before a call is transfered in a call handler if a caller has not made a selection. It does not give the caller the option of pressing the last option before it says "Wait while I transfer your call".
Michelle Awtrey
Partners HealthCare Systems
Voice Analyst
Rob Huffman
Hi Michelle,
One way to deal with this is by setting the;
On the greeting page itself. Would this work? You can also record a few seconds of silence
at the end of the greeting.
Cheers!
Rob
