Beginner
Unity Connection 8.6.2 - changing integration from SCCP to SIP
Hi all--I'm looking at potentially having to change the integration method of my Unity Connection deployment from SCCP to SIP to address an issue with caller-id showing up incorrectly and preventing users from simply tapping the number on the SMTP notification on their smartphones.  My question is how painful is it going to be to change integration types, and are there any major risks or gotchas that we need to be aware of before we move forward with the change?
thanks all
SJ
Everyone's tags (4)
1 ACCEPTED SOLUTION
Highlighted
Hall of Fame Master
This is not challenging at all, simply delete current integration on CUCM and UCXN completely i.e. on CUCM:
VM hunt pilot/hunt lists/line groups/SCCP ports
and VM ports and port group in UCXN
then follow the SIP integration guide to build new integration, i.e.
CUCM:
SIP trunks
Route Patterns/Route Lists/Route Groups
UCXN:
port groups (SIP)
ports
HTH,
Chris
3 REPLIES 3
Highlighted
Hall of Fame Master
CUCM:
SIP trunks
UCXN:
port groups (SIP)
ports
HTH,
Chris
Beginner
Thanks Chris--kind of thought that would be case, but wanted to confirm there wasn't anything that would come back and bite me later.
Appreciate it!
SJ
Beginner
Re: Unity Connection 8.6.2 - changing integration from SCCP to SIP
Chris,
Is the process the same with version 12.5.1?  I suspect it is...but never hurts to ask...
Cheers
Paul
Content for Community-Ad
August's Community Spotlight Awards
