1146
david
Beginner
Unity Connection 8.6.2a SU3 Subscriber Post upgrade issue
Upgraded our Unity Connection Servers last night from 8.6.2a SU1 to SU3.  Publisher completed fine (chose option not to reboot).  Subscriber reported it completed fine.  Switched versions on Publisher and waited for all services to restart before switching version on Subscriber.
Publisher all ok but get the following whne logging on to subscriber:
/usr/local/platform/bin/cliscript.sh: line 134: /usr/local/bin/base_scripts/xmlfoo: Permission denied
/usr/local/platform/bin/cliscript.sh: line 144: /usr/local/bin/base_scripts/xmlfoo: Permission denied
Command Line Interface is starting up, please wait ...
java.io.FileNotFoundException: /var/log/active/platform/log/cli.bin (Permission denied)
        at java.io.RandomAccessFile.open(Native Method)
        at java.io.RandomAccessFile.<init>(RandomAccessFile.java:216)
        at com.cisco.iptplatform.fappend.ciscoRollingFileAppender.restoreIndex(ciscoRollingFileAppender.java:104)
        at com.cisco.iptplatform.fappend.ciscoRollingFileAppender.setFile(ciscoRollingFileAppender.java:43)
        at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
        at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
        at java.lang.reflect.Method.invoke(Method.java:597)
        at org.apache.log4j.config.PropertySetter.setProperty(PropertySetter.java:196)
        at org.apache.log4j.config.PropertySetter.setProperty(PropertySetter.java:155)
        at org.apache.log4j.xml.DOMConfigurator.setParameter(DOMConfigurator.java:530)
        at org.apache.log4j.xml.DOMConfigurator.parseAppender(DOMConfigurator.java:182)
        at org.apache.log4j.xml.DOMConfigurator.findAppenderByName(DOMConfigurator.java:140)
        at org.apache.log4j.xml.DOMConfigurator.findAppenderByReference(DOMConfigurator.java:153)
        at org.apache.log4j.xml.DOMConfigurator.parseChildrenOfLoggerElement(DOMConfigurator.java:415)
        at org.apache.log4j.xml.DOMConfigurator.parseRoot(DOMConfigurator.java:384)
        at org.apache.log4j.xml.DOMConfigurator.parse(DOMConfigurator.java:783)
        at org.apache.log4j.xml.DOMConfigurator.doConfigure(DOMConfigurator.java:666)
        at org.apache.log4j.xml.DOMConfigurator.doConfigure(DOMConfigurator.java:616)
        at org.apache.log4j.xml.DOMConfigurator.doConfigure(DOMConfigurator.java:584)
        at org.apache.log4j.xml.DOMConfigurator.configure(DOMConfigurator.java:687)
        at sdMain.initialize(sdMain.java:479)
        at sdMain.main(sdMain.java:646)
java.lang.NullPointerException
        at com.cisco.iptplatform.fappend.ciscoRollingFileAppender.updateIndex(ciscoRollingFileAppender.java:117)
        at com.cisco.iptplatform.fappend.ciscoRollingFileAppender.nextFileName(ciscoRollingFileAppender.java:92)
        at com.cisco.iptplatform.fappend.ciscoRollingFileAppender.append(ciscoRollingFileAppender.java:74)
        at org.apache.log4j.AppenderSkeleton.doAppend(AppenderSkeleton.java:221)
        at org.apache.log4j.helpers.AppenderAttachableImpl.appendLoopOnAppenders(AppenderAttachableImpl.java:57)
        at org.apache.log4j.Category.callAppenders(Category.java:187)
        at org.apache.log4j.Category.forcedLog(Category.java:372)
        at org.apache.log4j.Category.debug(Category.java:241)
        at com.cisco.iptplatform.cli.CliSettings.getInstance(CliSettings.java:112)
        at sdMain.initialize(sdMain.java:491)
log4j:ERROR No output stream or file set for the appender named [CLI_LOG].
   Welcome to the Platform Command Line Interface
IOException : hardware API:Cannot run program "/usr/local/bin/base_scripts/ihardware_impl": java.io.IOException: error=13, Permission denied
admin:
Also when I issue a Show version Active command I get the following:
admin:show version active
java.lang.ArrayIndexOutOfBoundsException: 0 >= 0
        at java.util.Vector.elementAt(Vector.java:427)
        at com.cisco.iptplatform.cli.cmdPlatformVer.<init>(cmdPlatformVer.java:103)
        at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
        at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:39)
        at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:27)
        at java.lang.reflect.Constructor.newInstance(Constructor.java:513)
        at java.lang.Class.newInstance0(Class.java:357)
        at java.lang.Class.newInstance(Class.java:310)
        at com.cisco.iptplatform.cli.cmdClassThread.setCmdInstance(cmdClassThread.java:105)
        at com.cisco.iptplatform.cli.CliClassLauncher.execute(CliClassLauncher.java:285)
        at sdMain.main(sdMain.java:1826)
Active Master Version:
Active Version Installed Software Options:
uc-locale-en_GB-8.6.2.1-25.cop
Anyone with any ideas on what is wrong with the subscriber and how I can get this to come back up?  Appears as if it doesn't have permissions to run various scripts or the upgrade didn't domplete correctly even though it showed on the install log as successfully completed.
TIA
David
2 REPLIES 2
Rob Huffman
Hall of Fame Community Legend
Hi David,
I'm wondering if it may be this bug;
CSCua00059 Bug DetailsBug #13 of 16 | < Previous | Next >
Upgrade fail on SU releases when locales installed
Symptom:
Upgrade gets fail  on SU
Conditions:
locales are  installed
Workaround:
Please Contact Cisco TAC for Root Workaround
Status Status
Fixed
Severity Severity
4 - minor
Last Modified Last Modified
In Last Year
Product Product
Cisco Unity Connection
Technology Technology
1st Found-In 1st Found-in
8.5
8.6(2)
8.5(1)ES1
Fixed-In Fixed-in
8.6(2)ES43
8.6(2.22041.1)
8.5(1)ES98
8.6(2.22900.7)
8.5(1.15079.3)
8.6(2.22900.9)
Cheers!
Rob
"I don't know how, I don't know when
But you and I will meet again "
- Tom Petty
All,
we ended up reinstalling the Unity Connection serrver to resolve this issue.
Create
Recognize Your Peers
Content for Community-Ad
