unity connection 8.6 subscriber language installation
hi all,
would appriciate if someone call let me know if there is any downtime expected when installing a secondary unity connection with anohter language (french CA).  we have the primary up and running fine. when installing the french language we have to stop connection manager and connection mixer services. i am just wondering if this only for that server on which the language is being installed or not on both servers.  i am just little concern becuase the primary is already in production.
thanks a bunch.
vijay
Atul Khanna
Hi Vijay,
You can refer to the following link for adding a language to the unity connection cluster 8.x
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/upgrade/guide/8xcucrug027.html#wp1067223
If you want anyone to call you and explain the procedure, sorry to say but you might have to open a TAC case for that.
- Atul
Please rate, if this helps!!
