07-16-2012 05:21 AM - edited 03-19-2019 05:15 AM
Hi folks,
I have two question regarding ucn web inbox. Hope someone can help me...
If an unity connection user access his web inbox, he can access the ciscopca-website too. Is it possible to lock only the ability to access ciscopca-website globally or for an dedicated user?
If I forward a voicemail message to an other user, the message will be correct delivered (over smart host to external email-adresses or internal to ucn-mailboxes), but there is shown an error... please see screenshot attaced. Anyone knows, what this error should be?
Thanks in advance for your help.
Greetings, Chris
Solved! Go to Solution.
07-16-2012 06:19 AM
hi,
first question:
yes it's possible disable globally or for some profile, in Class of service - Voice Mail User COS - disable:
07-16-2012 06:19 AM
hi,
first question:
07-16-2012 06:26 AM
yes works as it should do. Thanks a lot!
