878
4rmorris
Beginner
Unity Connection 9.1.1 - Full Mailbox Check For Outside Callers option disappeared
Hi all,
We recently upgraded to version 9.1.1 of Unity Connection from 8.0.  Specifically, version 9.1.1.10000-32.
I was asked a question regarding outside callers getting warning about full mailboxes for my users, and went to double check that the option "Full mailbox check for outside callers" was not selected.  According to this doc and the help file with CUC, that option should appear on the System Settings -> Advanced -> Conversations page.
This option is not showing on my system.  It was there in version 7 and 8, and the docs say it should still be there.
Can anyone else confirm this behaviour?  Has the option moved somewhere else in the config?  Can anyone confirm if the system checks for full mailboxes for outside callers by default?  I haven't heard complaints from users yet, but if this behaviour has changed it could cause a lot of problems for people.  Help!
Ryan
1 ACCEPTED SOLUTION
Rob Huffman
Hall of Fame Community Legend
Hi Ryan,
Check this link;
Quotas are not enforced for messages left by  outside callers if the "Full Mailbox Check for Outside Caller Messages"  check box is not checked. This check box appears on the Message  Storage > Mailbox Quotas page.
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/9x/administration/guide/9xcucsag190.html
Cheers!
Rob
"go easy...step lightly...stay free "
- The Clash
3 REPLIES 3
Rob Huffman
Hi Ryan,
Check this link;
Cheers!
Rob
- The Clash
Thanks Rob!  The check box is there under the Mailbox Quotas page.  Looks like Cisco forgot to update the Help doc and some of the documentation pages when they moved it.  The behaviour of the system was carried through the upgrade.
Best regards,
Ryan
Rob Huffman
Hi Ryan,
You are most welcome my friend I have opened a thread
to see if we can get the docs corrected.
https://supportforums.cisco.com/thread/2220919
Cheers!
Rob
- The Clash
Create
Recognize Your Peers
Content for Community-Ad
