Unity Connection AA call handler.
r.robins
Hi All,
Can anyone give me any help regarding the configuration of an Auto Attendant Call Handler and the steps required to achieve the following:-
Call comes in to Main Site Number
CUCM (7.1.5) routes to Unity Connection
AA answers the call and gives an option to dial a known extension or hold for the operator.
Caller holds for operator - Unity forwards call to CUCM built in Attendant console Pilot Point
Operator answers the call During normal working hours. Outside of normal hours call is diverted to a separate extension in a 24/7 manned control room.
The Attendant consloe is currently working OK, and Unity is working for voicemail users but the documentiaon is very poor for the Call Handling side of things.
Jaime Valencia
If you know how to configure call handlers and greetings that's all there is for almost any AA config you need.
CTI RP with CFA to VM and matching call handler or  call routing rules to reach right call handler
Configure a separate call handler, under transfer settings set it to yes, ring subcriber at this extension: PP DN. On main call handler set the after greeting actions to Attempt transfer to: and use the previous call handler which has the PP DN configured under transfer.
Configure CUCM's TOD to achieve this. Working hours ring AC, after-hours configure a CTI RP with CFA to someone or use a translation pattern.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
