Unity Connection Auto attend question.
Unity Connection AA:
When an external Caller calls the main Board number, he/she will be greeted with an initial greeting followed by the prompts to select an option. When the external Caller selects an option, he/she will be transferred to the respective department. While waiting for the department to answer, instead of hearing the ringback tone, is it possible to play a custom music file to the caller ? please let me know the procedure to do the same.
Jaime Valencia
Nothing special, configure the MOH settings in the CUCM side as for any other endpoint and apply to the SCCP ports or the SIP trunk.
java
if this helps, please rate
