ā09-16-2016 04:08 AM - edited ā03-19-2019 11:35 AM
Dear Coleagues,
I would like to setup the PIN synchronization between CUC and CUCM, but when I click to Enable End User Pin Synchronization on the Application Server Configuration page I got this error:
Pin synchronization is not enabled due to HttpsURLConnection response code: 401 : Unauthorized
I have done the followings:
Is there anything I missed? Do I need to grant more privileges to the AXL application user?
Laszlo
Solved! Go to Solution.
ā09-16-2016 08:39 AM
I show the whole procedure in the video, I suggest you make sure everything is configured properly.
ā09-16-2016 07:44 AM
I don't see listed that you imported the CUCM cert into CUC
https://youtu.be/p6m4gPv0ikE
FYI, this works for LDAP or AXL users, you don't have to use AXL integration to CUCM for this to work.
ā09-16-2016 08:11 AM
Hi! Thanks for the hint, but unfortunately it did not solve the problem.
ā09-20-2016 05:27 AM
I had to create an CUC app user with admin privileges and then use it during the Application server setup on CUCM.
Thanks for the video,
Laszlo
ā11-23-2016 12:05 PM
Hi Laszlo...
Thanks for this....i did work for me as well.....creating the CUC admin user to match the user from Application Server on CUCM.
ā07-26-2017 09:53 PM
Agreed.
In In my case, the AXL test passed on the telephony integration page without having the CUC user created. But whenever I tried to enable the PIN sync checkbox in UCM, I would get the error: "Pin synchronization is not enabled due to HttpsURLConnection response code: 401 : Unauthorized.ā Bunch of TAC case hits point to the following:
For PIN synchronization to work, a user account (doesn't need to have a mailbox) must be configured in Unity with a password. This user account's alias and password must match that of whatever application user is configured on the Unity Connection server under System>Application Server in CUCM. If the alias and or password doesn't match, the following error is thrown in CUCM when enabling PIN synchronization checkbox: "Pin synchronization is not enabled due to HttpsURLConnection response code: 401 : Unauthorized"
So if you create a dedicated AXL application user it must be defined in three places:
UCM Application User: CUC-AXL-User (AXL Role)
CUC User: CUC-AXL-User (No Mailbox, administrativetemplate)
CUC AXL Telephony Integration Page: CUC-AXL-User
of course passwords should match in all three places.
ā04-09-2018 01:31 PM
ā04-06-2017 08:52 AM
Hello Jaime,
can you list the steps required to download the certificate from CUC?
it's not clear in the video how you've done it...
ā04-06-2017 08:54 AM
Go to OS admin, find the tomcat certificate, click on it, click on download
ā04-06-2017 08:58 AM
just to make sure that we are talking about the tomcat and not tomcat-trust certificate right?
Do i download it as .PEM or .DER? or it doesn't matter?
ā04-06-2017 09:47 AM
Yes, you need the server certificate.
It shouldn't matter, I usually use .pem
ā04-06-2017 10:16 AM
i've done this but it's still not working... i deleted the app server and recreated again with no problem resolution. i'm getting the error:
Pin synchronization is not enabled due to Certificate not verified.
i will open a TAC case.
ā10-25-2018 04:48 AM
ā08-31-2021 04:36 PM
Hola Jaime, no he podido ver tu video, dice que lo han quitado de youtube por que la cuenta de YT ya no existe, puedes subirlo a otra plataforma de streaming? o re subirlo a YT por favor
