Dear Coleagues,
I would like to setup the PIN synchronization between CUC and CUCM, but when I click to Enable End User Pin Synchronization on the Application Server Configuration page I got this error:
Pin synchronization is not enabled due to HttpsURLConnection response code: 401 : Unauthorized
I have done the followings:
- Started the AXL on CUCM
- Created a new AXL related application user with Standard AXL API Access on CUCM
- Imported the CUC tomcat certificate into the CUCM cert store as tomcat trust
- Setup CUC as an Application server on CUCM with AXL application user
- Setup CUCM under Telephony intergrations - Phone System - AXL Server on CUC (with the AXL application user credentials, SSL enabled and PIN sync)
- Setup end users with primary extensions
- Imported the users from CUCM
Is there anything I missed? Do I need to grant more privileges to the AXL application user?
Laszlo
