Unity Connection, Sender Display Name
blake.macisaac1
Hello All,
I've recently setup Voicemail to Email services within out unity connection server, its working as intended.
The question i have is, how do i change the display name of the sender "Cisco Unity Connection Messaging System" to something more specific to our organization.
Blake
This is working as designed, however we can change the name from CLI with SQL query which requires database update. have a check with TAC once and refer below thread for the workaround.
https://supportforums.cisco.com/discussion/11157841/85-unity-connection-um-tweaks
Anil Sharma
Hi Blake, I need to do Voicemail box and email (Microsoft outlook) integration for one of my customer so can you please share the configuration steps which you followed for this, it will help me. Thanks in advance. Anil
Hello Anil,
i followed this document.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/10x/unified_messaging/guide/10xcucumgx/10xcucumg020.html#58853
Basically, the biggest thing to remember is to create a user within exchange that has the ApplicationImpersonation managment role.
Its all detailed in the document above, there is also a specific document on how to complete this with Office 365 deployments.
Hope this helps
Blake
