04-06-2019 07:07 PM
I have a Unity connection vers 11.5. When I log on I see Communication not function between servers.
DBreplication runtimestate is fine. All tests run fine except the show cuc cluster status shows this on the subsciber:
admin:show cuc cluster status
Server Name Member ID Server State Internal State Reason
mldcunitycp 0 Disconnected Unknown Unknown
chunitycs 1 Primary Sec Act Primary Disconnected Normal
SERVER ID STATE STATUS QUEUE CONNECTION CHANGED
g_ciscounity_pub 100 Active Dropped 37463993 Apr 6 21:47:05
g_ciscounity_sub1 101 Active Local 0
SERVERS
Server Peer ID State Status Queue Connection Changed
g_ciscounity_pub Down
g_ciscounity_sub1 g_ciscounity_pub 100 Active Dropped 37463993 Apr 6 21:47:05
STATE
Source ER Capture Network Apply
State State State State
g_ciscounity_pub Uninitialized Uninitialized Down Uninitialized
g_ciscounity_sub1 Active Running Running Uninitialized
This is the only thing I see wrong.
Anyone seen this
04-07-2019 07:41 AM
The above message with the dbreplication runtimestate being normal does not seem right to me. Can you post results of 'show dbreplication runtimestate' on both your CUC pub and sub?
Maren
04-08-2019 09:59 AM
Here you go
Cluster Detailed View from mldcunitycp (2 Servers):
PING DB/RPC/ REPL. Replication REPLICATION SETUP
SERVER-NAME IP ADDRESS (msec) DbMon? QUEUE Group ID (RTMT) & Details
mldcunitycp 10.X.X.10 0.017 Y/Y/Y 0 (g_2) (2) Setup Completed
chunitycs 10.X.x.10 0.191 Y/Y/Y 0 (g_3) (2) Setup Completed
Cluster Detailed View from chunitycs (2 Servers):
SERVER-NAME IP ADDRESS (msec) DbMon? QUEUE Group ID (RTMT) & DB Status
mldcunitycp 10.X.X.10 0.190 Y/Y/Y 0 (g_2) (2) Setup Completed
chunitycs 10.X.X.10 0.014 Y/Y/Y 0 (g_3) (2) Setup Completed
04-08-2019 10:43 AM
What is the date that is shown on the 'utils dbreplication runtimestate'? Is is recent? If not, try running "utils dbreplication status" on the pub, then wait for a while and run the "utils dbreplication runtimestate" again.
Some other questions:
I might also suggest rebooting the Pub and then the Sub. (Unless you've tried this already.)
Let us know and we'll figure out what to do.
Maren
04-09-2019 08:30 AM
All the data is 100% current. I can logon to each of the servers. The NTP servers are fine. I have rebooted several times, ran split brain recovery three times now. The problem I think is this SRM,3,<sess-2> Rejecting registration due to different instance IDs. Remote: b54ae2aa-074f-4bbd-bcc5-30f695fdc982 Local: 87852e41-7524-4900-9006-670cee0b6a1a
But I am not sure why it is happening.
04-09-2019 09:08 AM
For me it would be TAC time. There might be another person on the forums who can help.
I did run across this, though:
CUC 8.5.1 Both Servers Have Primary Server Status
If you do find a solution, please let us know!
Maren
