02-20-2019 02:24 PM
Does anyone know a sql query for unity connection which will show just Alias and Extension?
Solved! Go to Solution.
02-20-2019 06:01 PM
if you just want the alias and primary extension of the user you can simply get them both from the vw_subscriber view:
select alias, dtmfaccessid from vw_subscriber
If you need all the possible extensions for users (users can have 10 alternate extensions for instance) you'll need to pull them in from the vw_dtmfaccessid view like this:
select vw_subscriber.alias, vw_dtmfaccessid.dtmfaccessid from vw_subscriber, vw_dtmfaccessid where vw_dtmfaccessid.Parent_SubscriberObjectId = vw_subscriber.ObjectId order by alias
02-20-2019 06:01 PM
02-21-2019 09:27 AM
04-04-2019 05:42 AM
04-04-2019 06:22 AM
if you're running this at the Unity Connection admin command line you need to prefix "run cuc dbquery unitydirdb " in front of the SQL query there - UnityDirDb is the main directory database for Unity (as opposed to the MbxDbs for messages and such).
Not sure what you're trying to query here with regards to calling party - are you wanting to search for messages in the database from particular calling numbers or the like?
04-04-2019 08:42 AM
Many thanks
something like this, this is from CUCM. similarly from CUC I am looking for customer number,subscriber and date time
call_type callingpartynumber originalcalledpartynumber datetimestamporigination
S 113122 113118 2019-02-04 09:29:11
S 113122 13146529924 2019-02-04 13:32:43
