Upgrade from Unity 7 to Unity 8 and now web interface is showing labels
mike083108
Beginner
Beginner
Hey Everyone,
I just upgraded one of my servers from unity 7 to unity 8.  So far it looks like everything went as planned, however, the web admin page is showing labels for all of the text.  Check out the attached image to see exactly what I am talking about.
How can i fix this?
Thanks!
1 ACCEPTED SOLUTION
Bradford Magnani
What media did you use for Unity 8.x?  Shipped media or downloaded from cisco.com?  There was this nasty defect that caused a lot of side effects (one of this was this label issue) for the initial shipped 8.x media: http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCth77070
Have you tried running MSCW with success since doing the upgrade?  If you run into the error noted in the defect, you'll know you're hitting it.
Hope that helps,
Brad
4 REPLIES 4
Bradford Magnani
Hope that helps,
Brad
I definitely hit the issue with the MSCW.  I successfully passed it thanks to one of your responses to another
member on the forum.  I was hoping I would not have to reinstall but I have a feeling you will confirm that I should reinstall with downloaded media.  Correct?
I'm afraid so... otherwise you could be chasing numerous symptoms down the road that could cause a larger headache..
Brad
Ok will do.  Thanks for the quick response!
It's funny because I normally do all of my upgrades with downloaded media.  This is the first time I used shipped media.... and now my last!
