i´m wondering if anyone can explain me the reason for this procedure in the 9.1 upgrade guide:
There is a statement that we have to do the upgrade to 9.1, do a drs backup and then install the whole thing from scratch!
I see a lot of problems and a tremendous amount of time for the upgrade.
I spoke to my vmware guys and no one can understand why we not only upgrade the virtual hardware and vmtools and that´s it.
Best regards
Steffen
Solved! Go to Solution.
Hi Steffen,
I'm not sure of your upgrade path, but the one linked above
assumes a migration from MCS hardware to Virtual build
as part of the listed process. This is shown in this step (Step 6);
After the DRS backup is complete, shut down the existing cluster to avoid any conflict with the virtual installation of the cluster.
So, if you are already running on a VM build this would not be applicable
Cheers!
Rob
"Hours are like diamonds, don't let them waste
Time waits for no one, no favors has he"
- Stones
Hi Steffen,
Cheers!
Rob
- Stones
...ok.
I was confused about the steps mentioned in the upgrade guide, expected something new...
And in fact i´m not a native speaker...;-)
...than it´s the way we have done it for years.
So i can relax and have a beer ;-)
Steffen
Hi Steffen,
Have one for me as well
Cheers!
Rob
PS: your English is excellent ...so no worries!
- Stones
