Use G729 between CUCM and CCME on IP WAN
nicanor00
I have cucm 8 with router 2900 voice gateway on central site and CCME on 6 remote site (let say site A,B,C,D,E,F)
I need to reduce IP phone to ip phone call bandwidth on IP WAN between some site
Now I use G711 for all call
see below what  I plan to do
- Use G729  for call between cucm IP phone and ccme ip phone site (A,B,C,D)  and between ccme site (A,B,C,D)
- Internal ip phone call on each site (central site and site A,B,C,D,E,F)  will use G711 as now
- ip phone Call going and comming from site E and F to all other site (central site and site A,B,C,D) use G711 as now
I dont know how to implement it
I am new on this type of configuration
I already installed PVDM card on voice gateway and CCME
I need transcoding only for ip phone to ip phone call on the IP wan between some site
I use ip phone : 7962, 7942, 6921, 7911
Please help
Jaime Valencia
Configure the region between the CUCM phones and the H323/SIP trunk you use to reach CME to use G729.
On CME configure G729 directly under the VoIP DPs you use to reach other CMEs/CUCM or use a voice-class codec config.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Chris Deren
Change your dial-peer configuration pointing to site other sites that you want to use G729 to use G729 codec, you do not need any transcoders for this. Basically assume site A to site B calls as 4XXX, your dial-peer should be :
dial-peer voice 10 voip
description site B
destination-pattern 4...
session target ipv4:x.x.x.x
codec g729r8
no vad
On CUCM you will need to change the region configuration to use G729 pointing to the CME GWs.
HTH,
Chris
Thanks for your answer
I will try it
I wich case do I need transcoding ?
If I change only the codec as you suggest, conference call will still work ?
If not how can I configure it ?
Nic
paolo bevilacqua
I would recomend you think over and keep G.711 configured as only codec.
Let alone the bandwidth saving, that in today's networking is marginal, you will enjoy a better call quality, simplicity, and stability.
