Using Unity Connection to play greeting then transfer to UCCX
James Gladwell
I have a contact service queue set up for our Help Desk.  My director wants to put in a way to quickly update system outage status.  Currently, we use x74357 as our line, which translates to the UCCX trigger.  I want to change that so it forwards automatically to voicemail.  I was thinking that in Unity Connection, if we setup a standard greeting on the Help Desk mailbox of "There are no current system outages" and allow the alternate greeting to be changed as different systems are affected by outages.  At the end of this greeting, can we automatically send it to the UCCX trigger where it gives them our standard options "Press 1 for password reset, 2 for next available agent, etc..."
Rob Huffman
Hi James,
That should be most possible
If you pulled the x74357 number trigger then you would have
to replace it with a new "hidden" trigger number.  I would use
2 new Call handlers to accomplish this. Use the first one for
x74357 where the greetings reside & can be easily changed
and then use the After greeting Action to transfer to the second
Call handler. On this one you can set it with no greeting recorded
and use the tansfer setting to route to the new trigger#.
You can use a CTI-RP in CUCM to route x74357 to route the
initial call to Unity connection to pick up the Call Handler on the
same number.
Cheers!
Rob
"May your heart always be joyful
And may your song always be sung
May you stay forever young "
- Dylan
