voicemail to email for external calls is not working for some calls
Isaac
whenever someone externally calls in and leaves a voicemail users won't be notified half the time and the other time they will. Internally this all works as it should, it is only when someone calls in externally.
Vaijanath Sonvane
Are the incoming calls coming on same or different PRI/SIP Trunk lines? If it is different, then do you have correct Calling Search Space (CSS) configured on it with access to voicemail partition.
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
