02-04-2008 06:42 AM - edited 03-18-2019 08:25 PM
I'm using CME 3.3 on 2800 router. Also using 7912 and 7940 and 7960 phones.
The issue is like this.
When the People in our plant are in a call and they try to adjust the reciever volume because they are in a loud environment,Then the external speaker switched on and the people here a very noisy and scratching noise.
Please help in getting this issue resolved.
02-08-2008 01:30 PM
Symptoms:
IP phone registered to a CCM server loses ability to call other phones or out to the PSTN after the phone is reset. Once the condition starts occurring, any additional phone that is reset is likely to experience the same failure. CCM trace shows that the CallManager is no longer honoring the Calling Search Space(CSS) configured for the IP phone.
example from CCM trace:
Cisco CallManager|Digit analysis: match(fqcn="4003", cn="4003", pss="", dd="9")
This snippet of CCM trace shows an attempted call from x4003. The pss should be a list of valid partitions to be searched for the dialed destination (dd). The pss shows no valid partitions even though in CCMAdmin both the phone device and the phone line are configured with CSS containing several partitions
Conditions:
CallManager in a cluster of 2 or more servers. This is due to a handle leak in the CCM.exe process. Open task manager on the callmanager server, select the process tab, select view, then select columns, check the box for handle count, select OK. Find the CCM.exe process and the assocaited handle count. On most systems the handle count for CCM.exe should be less
than 10,000. The handle count is dependant on the system configuration and registered devices, so it is best to benchmark a system handle count immediately after a restart and then monitor for upward trends. Handle counts can also be monitored and recorded through performance monitor start->programs->administrative tools->performance for easier recording and
trending.
Issue introduced in CCM 3.2(2c)spG and resolved in 3.2(2c)spH
Issue introduced in CCM 3.2(2c)ES39 and resolved in 3.2(2c)ES63
Workaround:
Register the IP phones to a backup server OR reboot the affected call processing server. Then upgrade CCM to a fixed version for a long term fix.
