Mega raid option does not appear when the server comes to the bios screen, I see the Megar aid PCI card when I look at the bios but I can not do in the configuration because all setting is disable. There are three from this server and they all have the same status
8 Comments
Can you uploud image of your problem.??
I can't understand whats your question.
Bios_Boot_Screen.PNGBios_Advanced.PNGLOm_PCI.PNGConf1.PNGConf2.PNGBios_boot.PNGVirtula_Drive_Disable.PNG
Raid card configuration does not appear on the bios screen. The ctrl + m combination does not work. I am trying to create a raid configuration on the server  but I cannot access the raid controller configuration screen.
Features of the server;
UCS C240 M5 12 LFF + 2 rear drives w/o CPU,mem,HD,PCIe,PS1
SNTC 8X5XNBD UCS C240 M5 12 LFF1
Riser 1 incl 3 PCIe slots (x8, x16, x8); slot 3 req CPU21
Riser 2A incl 3 PCIe slots (x8, x16, x16) supports GPU1
Cisco UCS 770W AC Power Supply for Rack Server2
Power Cord, 250VAC 10A CEE 7/7 Plug, EU2
IMC SW (Recommended) latest release for C-Series Servers.1
Heat sink for UCS C240 M5 rack servers 150W CPUs & below2
UCS C-Series M5 SFF drive blanking panel2
C-Series M5 LFF drive blanking panel10
Intel X520 Dual Port 10Gb SFP+ Adapter1
Data Protection Platform1
Other Workload1
Qlogic QLE2692 dual-port 16G FC HBA2
Cisco 12G Modular SAS HBA (max 16 drives)1
1.7 GHz 3104/85W 6C/8.25MB Cache/DDR4 2133MHz2
16GB DDR4-2666-MHz RDIMM/PC4-21300/single rank/x4/1.2v2
240GB 3.5 inch Enterprise Value 6G SATA SSD2
You must to configuration RAID in CIMC manager..
Step1:Set IP for CIMC (Press F8 in start page)
Step2:Browes ip address
Step3:In storage Tab select Cisco 12G Modullar RAID Controller......
Step4:Then select Physical Drive info and ensure that your HDD does not in JBOD mode if in this mode change it in to" NOT Configured" mood..
so that you can configure RAID Configuration...
BR
Now the cimc settings are like in the image files. but there is still nothing working.
HarishaSC54769
As per your features listed and screenshots, your C240M5 server is in UEFI mode and it's loaded with "Cisco 12G Modular SAS HBA (max 16 drives)" card. And this card doesn't support any RAID configuration, only pass-through mode.
Please refer C240M5 spec **bleep** for more info(https://www.cisco.com/c/dam/en/us/products/collateral/servers-unified-computing/ucs-c-series-rack-servers/c240m5-lff-specsheet.pdf)
