CIMC Will NOT Set Power Policy (C-Series 210 m2)
kphillips
Question: I am unable to set power policy through web GUI and CLI on a C-series 210 m2.
Description: An engineer who uses this machine for testing utilized the power-on with 1 sec delay for ~400 shutdown-power-on cycles, I assume that the CIMC is not designed for this purpose and so many cycles could have been detrimental to the health of the module. The engineer contacted me to say the web interface would not allow him to set power policy through the GUI, when acessing the power policy tab the following error was produced: "ERROR: Operation Failed". I then attempted to set the policy through the CLI with the follow commands:
ucs-c210-m2 /chassis *# set policy power-on
cli          delay        delay-value  description  locator-led  policy
ucs-c210-m2 /chassis *# set delay-value 1
ucs-c210-m2 /chassis *# commit
Internal error happened, "set" operation failed
Error: Operation failed
ucs-c210-m2 /chassis *# show configuration pending
Modify  /chassis
  policy  power-on
  delay-value  1
This worries me. So I checked the logs.
SEL:
Time                Severity      Description
[System Boot]       Informational "LED_DIMM_STATUS: Platform sensor, OFF event was asserted"
[System Boot]       Critical      "PSU_REDUNDANCY: PS Redundancy sensor, Redundancy Lost was asserted"
[System Boot]       Normal        "PSU1 PSU1_STATUS: Power Supply sensor for PSU1, Presence detected was asserted"
[System Boot]       Informational "LED_FPID: Platform sensor, BLUE was asserted"
[System Boot]       Informational "LED_FPID: Platform sensor, OFF event was asserted"
[System Boot]       Critical      "FRU_RAM SEL_FULLNESS: System Event sensor for FRU_RAM, failure event, Upper Critical going high was asserted"
[System Boot]       Normal        "MAIN_POWER: Presence sensor, Device Removed / Device Absent was asserted"
[System Boot]       Informational "LED_CPU_STATUS: Platform sensor, AMBER was asserted"
[System Boot]       Informational "LED_CPU_STATUS: Platform sensor, OFF event was asserted"
[System Boot]       Informational "LED_PSU_STATUS: Platform sensor, AMBER was asserted"
[System Boot]       Informational "LED_PSU_STATUS: Platform sensor, OFF event wa
s asserted"
[System Boot]       Normal        "FRU_RAM POWER_ON_FAIL: Platform sensor for FRU_RAM, Predictive Failure deasserted was asserted"
[System Boot]       Informational "LED_HLTH_STATUS: Platform sensor, GREEN was asserted"
[System Boot]       Informational "LED_HLTH_STATUS: Platform sensor, ON event was asserted"
[System Boot]       Normal        "BIOS_POST_CMPLT: Presence sensor, Device Inserted / Device Present was asserted"
2012-01-30 20:42:38 Normal        "MAIN_POWER: Presence sensor, Device Removed / Device Absent was asserted"
2012-01-30 20:38:58 Normal        "BIOS_POST_CMPLT: Presence sensor, Device Inserted / Device Present was asserted"
2012-01-30 20:38:58 Normal        "System Software event: System Event sensor, OEM System Boot Event was asserted"
2012-01-30 20:37:52 Informational "LED_HLTH_STATUS: Platform sensor, ON event was asserted"
2012-01-30 20:37:52 Normal        "System Software event: System Event sensor, Timestamp Clock Synch (second of pair) was asserted"
[System Boot]       Normal        "System Software event: System Event sensor, Timestamp Clock Synch (first of pair) was asserted"
[System Boot]       Normal        "CATERR_N: Processor sensor, Predictive Failure deasserted was asserted"
CIMC
N.B. The issue first started sometime this weekend (1/30-1/31).
I was thinking that burning the CIMC firmware onto the module could solve the issue, but given I have little experience with Cisco equipment I figured it would be a good idea to ask first. Any thoughts?
padramas
Kevin,
I was able to apply the configuration in my lab server ( C210 M1 ) running CIMC version 1.4(2) version.
ucs-c210-m1 /chassis # show detail
Chassis:
    Power: off
    Product Name: UCS C210 M1
    PID : R210-2121605
    Locator LED: off
    Description:
    Power Restore Policy: power-on
    Power Delay Type: fixed
    Power Delay Value(sec): 1
Then I revered the change via GUI and was able to successfully re-apply the same configuration.
http://www.cisco.com/en/US/docs/unified_computing/ucs/c/sw/cli/config/guide/1.4.1/Cisco_UCS_C-Series_CLI_Configuration_Guide_141_chapter3.html#task_7CD57F360073470DB06952F8525E828E
Can you please share the output of the show detail after scoping into chassis ?
Padma
Here is the results of scope chassis -> show details
ucs-c210-m2 /chassis # show detail
Chassis:
    Power:
    Serial Number: ***************
    Product Name: UCS C210 M2
    PID : R210-2121605W
    UUID: *************************
    Locator LED: off
    Description:
    Power Delay Type:
Keep in mind this after ~400 power cycles in a weekend.
Kevin,
I would suggest you to open a TAC Service Request to further investigate this issue.
Also, please try to apply the configuration again and collect the CIMC show tech log bundle and upload it to the SR.
Collecting CIMC show tech log bundle
http://www.cisco.com/en/US/docs/unified_computing/ucs/c/ts/guide/TS_90ContactSupport.html#wp1085343
Padma
Hi Kevin did you find a resolultion to this, we are seeing the same error on our c210m2 running 1.4.2.  We had the server freeze up and had to powercycle it.
