Cisco UCS 6248 + Cisco Nexus 5548 + EMC VNX 5500 Configuration Help
Amit Vyas
I need help to configure my Cisco UCS 6248 + Cisco Nexus 5548 + EMC VNX 5500, I have a following connectivity in place
FI-6248-A to N5K-A - 4xFCoE
FI-6248-A to N5K-B - 4xFCoE
FI-6248-B to N5K-A - 4xFCoE
FI-6248-B to N5K-B - 4xFCoE
VNX SPA-P1 - N5K-A-1/31 on 8G
VNX SPA-P2 - N5K-2-1/32 on 8G
VNX SPB-P1 - N5K-B-1/31 on 8G
VNX SPB-P2 - N5K-A-1/32 on 8G
What configuration I need to do at 6248 & 5548 Level so I can able to populate LUNs from VNX to my ESXi hosts
-Amit
padramas
Hello Amit,
Is it FCoE end to end or FC between N5K and VNX ?
UCSM 2.1 is required for FCoE uplink from FI.
Sample configuration is available here
https://supportforums.cisco.com/thread/2205748?tstart=30
If it is FCoE towards VNX, configuration would be similar as above. If not, you can refer to following guide for FC interface configuartion.
http://www.cisco.com/en/US/products/ps9670/products_installation_and_configuration_guides_list.html
Padma
Following is the answers for the question you asked
Is it FCoE end to end or FC between N5K and VNX ? - FC between N5K and VNX
I am running 2.1(1a) and I have gone thru sample configuration which you have provided
For FC we have made port 29-32 type FC on 5548
I have post one more configuration help question in same fourm
