Connect UCS to Nexus
zhiqiang.yan
I am adding UCS FI to our network, connect to a Nexus switch. our network has multiple isolate Vlans, and normal Vlans, that all need to be trunk to FI. On switch port, should I do normal trunk mode, or private-vlan trunk mode.
Walter Dey
In general, all vlan's defined in a UCS domain are trunked on all Nortbound links, see
http://www.cisco.com/c/en/us/support/docs/servers-unified-computing/ucs-manager/116095-configure-ucs-upstream-port-channel-00.html
However, there is also the concept of disjoint vlan's, see
http://www.cisco.com/c/en/us/solutions/collateral/data-center-virtualization/unified-computing/white_paper_c11-692008.html
Walter.
Walter Dey
Walter.
Thank You.
