FI firmware upgrade from 2.2(3a) to 2.2(5a)
mike-maier
I am trying to activate the firmware on the subordinate and i get :Result: end-point -failed Code: unspecified  Message: Pre-Upgrade failed.  Insufficient free space in /var/tmp. Less than required 90%.   If i could find this location or how to get there i might be able to clean it up.  Any help would be great.
Saurabh Kothari
Mike,
we'll need to check the utilization of /var/tmp (the fault will be thrown if it is more than 10%).
sometime there are files in /var/tmp that oversize and eat up space.
Open a TAC case and ask the engineer to check bug# CSCun79792 and perform the workaround.
Once the files in /var/tmp have reduced size and overall utlization of /var/tmp is below 10% firmware upgrade should be able to proceed.
Saurabh
Marcin Latosiewicz
There are a couple reasons this good be happening, starting from bad mounting/bad reporting to some files growing over the limit.
vide:
https://tools.cisco.com/bugsearch/bug/CSCun79792/?reffering_site=dumpcr
My suggestion - get TAC involved.
Saurabh Kothari
Mike,
Saurabh
mike-maier
https://supportforums.cisco.com/discussion/12519076/cscup37354-vartmp-and-varsysgmr-full-due-generated-cores
I rebooted the interconnect it is now updating as per this article.
