ā12-29-2019 12:03 PM
hi i'm still confuse how to install centos 7 or 6 into ucs c22 m3 standalone. i try to install and i can't detect drive i try to search in google and check documentation, and i know that i need install the drivers first. but i still confuse how to load the driver and which iso is right from documentation. this is my first time installing os into server and i'm student.
ā12-30-2019 04:02 AM
check below guide may help you :
https://www.ikt-handel.no/pdf/070DF761-62A3-4B7B-A698-8E384F13F60F.pdf
ā12-30-2019 04:44 AM
it is work for ucs c22 m3 standalone using cimc and for centos ? https://www.cisco.com/c/en/us/support/docs/servers-unified-computing/ucs-m-series-modular-servers/200469-Install-Redhat-CentOS-Operating-System-o.html ? how to get a snic driver. in the iso driver i just found fnic and enic.
ā12-30-2019 07:21 AM - edited ā12-30-2019 07:36 AM
Greetings.
Please see https://www.cisco.com/c/en/us/support/docs/servers-unified-computing/ucs-manager/116349-technote-product-00.html and https://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/c/hw/C22/install/C22/raid.html#68731
Your server is a 'C' series server, not a "M" series server, in regards to the "S-NIC" driver, which does not pertain to C series servers.
For storage driver purposes you will likely need to confirm the megaraid_sas driver.
Also, if you are creating a virtual drive/raid volume, then you will need to complete that prior to trying to load the OS.
Kirk...
ā12-30-2019 04:01 PM
yes i try this step. but i can't install the driver. i still confuse with this step
Preparing Installation Disks With a Linux Operating System:.
ā05-12-2021 02:33 AM
Did you managed to install centOS7 this server with RAID?
ā05-12-2021 02:51 AM
I was unsuccessful to install centos 7 on this server. I only managed to install SUSE Linux Entreprise, OpenSUSE and Windows Server.
