nexus 1000v svs connection increase max-port increase
speedfreax
Hello All,
Does anybody know the impact if I increase the max-ports under the svs connection from 8192 to 20.000.
We are using ESX version 5.0
Best regards
lwatta
You shouldn't have any problem. 20,000 is a supported number for vCenter 5.0.
You can verify by checking the VMware vSphere Configuration Maximums guide for 5.0.
Looking at the guide I have it says the number of Distrbuted virtual network switch ports per vCenter is 30,000.
louis
Hello Iwatta,
Thank for your answer, do you know if it has impact if I change it to 20.000?
