NEXUS 5596 UP 1/ 10G show as NOT-CONNECTED
Raymond Tan WM
I've tried to connect Nexus 5596 ethernet port(1G) to a ISR C2951 Gi port.  I have config the unified port for 1G.  The router end is "up" but the switch status keep showing as "not connect".  Is there any other additional configuration needed?
Nexus 5596#
interface Ethernet2/1
  switchport access vlan 50
  speed 1000
prnwsw31# sh int e2/1 status
Port          Name               Status    Vlan      Duplex  Speed   Type
Eth1/14       --                 notconnec 50        full    1000    SFP-1000BAS
Ethernet2/1
    transceiver is present
    type is SFP-1000BASE-T
    name is CISCO-AVAGO
    part number is ABCU-5710RZ-CS4
    revision is B2
    serial number is AGM170220UY
    nominal bitrate is 1300 MBit/sec
    Link length supported for copper is 100 m
    cisco id is --
    cisco extended id number is 4
Software
  BIOS:      version 3.6.0
  loader:    version N/A
  kickstart: version 5.2(1)N1(1b)
  system:    version 5.2(1)N1(1b)
  power-seq: Module 1: version v5.0
             Module 2: version v1.0
             Module 3: version v1.0
  uC:        version v1.0.0.2
  SFP uC:    Module 1: v1.0.0.0
Leo Laohoo
Is this a GLC-T or SFP-GE-T?
Hardware Supported
it is GLC-T.  The funny thing is when i connect to 1G port on another Nexus 5596.  It show as "connected".
Is there any other configuration require when i connect to other devices such as Cisco ISR/ASA or checkpoint?
Speed and duplex should be auto.
Speed have to set to 1000 in-order to use the 1G SFP for the Nexus 5596 unified port. It won't detect the SFP if otherwise.
