there is no place to bind vSan to FCoE Port-Channels
I'm building a brand new UCS system which is running 2.2(3g). The plan is to use FCoE uplinks and it's going to be in a multi-hop FCoE configuration.
To my surprise , there is no place to assign the FCoE port channel to a specific vSan , instead I do have a new option for LACP policy.
we do have the option in older firmware but for some reason it either does not exist or I cannot find it.
FC works fine and after creating an FC Port-Channel I can assign the vsan with no issues.
Interface  Vsan   Admin  Admin   Status      Bind                 Oper    Oper
                  Mode   Trunk               Info                 Mode    Speed
                         Mode                                            (Gbps)
vfc915     1      NP    on     trunking    port-channel141          TNP  auto
vsan 1 interfaces:
    vfc915
vsan 3042 interfaces:
vsan 4079(evfp_isolated_vsan) interfaces:
vsan 4094(isolated_vsan) interfaces:
Any thoughts ?
13 Replies 13
Jing Ren
Hi Mohammad,
I guess probably you mis-understood port-channel and san-port-channel from your config. Your output seemed to be a proper bind of your vfc915 to an etherchannel 141. You should either assign a vsan or trunk vsans to your vfc interfaces.
This link might explains steps in detail:
http://www.cisco.com/c/en/us/support/docs/switches/nexus-5000-series-switches/116248-configure-fcoe-00.html
HTH,
James
James;
I'm aware of the adapter level vsan assignment for the vhbas, this is about vsan assignment on the FCoE uplink ports.
Attached, is the screenshot from my other UCS running an older code.
Did you tried from cli mode....?
You cannot configure NXOS from CLI on UCS
James;
Even in the document which you sent me you can clearly see in step 8 that we can select the vsan and assign in to the FCoE port channel uplinks.
For some reason which is unknown to me , we do not have this option in 2.2(3g)
Hi Mohammad,
The VSAN dropdown list page is using the same gui page as FC port-channel, that's why you see a VSAN in both locations. In FCoE Po the vsan actually refers to the fcoe vlan mapped to vsan.
If you want to limit vsans trunked in the uplinks, right click Fabric A/B, and disable FC uplink trunking.
Please note by default vsan 1 is trunked, you can't disable that.
J
Hi James;
FC Uplink Trunking is disabled by default. Enabling or disabling that does NOT make any difference on FCoE uplink ports.
As you can see here I do have 2 port-channels connected to 2 different fabrics and UCS created vfc 734 and 740.
I want admin allowed vsans to be 3042 for vfc 734 and 40 for vfc 740.
vfc734 is trunking (Not all VSANs UP on the trunk)
    Bound interface is port-channel141
    Hardware is Ethernet
    Port WWN is 22:dd:00:2a:6a:43:d9:3f
    Admin port mode is NP, trunk mode is on
    snmp link state traps are enabled
    Port mode is TNP
    Port vsan is 1
    Trunk vsans (admin allowed and active) (1,40,3042)
    Trunk vsans (up)                       (3042)
    Trunk vsans (isolated)                 ()
    Trunk vsans (initializing)             (1,40)
    1 minute input rate 0 bits/sec, 0 bytes/sec, 0 frames/sec
    1 minute output rate 0 bits/sec, 0 bytes/sec, 0 frames/sec
      9 frames input, 1056 bytes
        0 discards, 0 errors
      300 frames output, 42692 bytes
    last clearing of "show interface" counters never
    Interface last changed at Tue Jun 23 14:00:17 2015
vfc740 is trunking (Not all VSANs UP on the trunk)
    Bound interface is port-channel139
    Port WWN is 22:e3:00:2a:6a:43:d9:3f
    Port mode is TNP
    Port vsan is 1
    Trunk vsans (up)                       (40)
    Trunk vsans (initializing)             (1,3042)
      24 frames input, 3948 bytes
      20 frames output, 2576 bytes
    Interface last changed at Thu Jun 25 14:11:18 2015
so right now , I'm just doing this by limiting the allowed vsan list on my NEXUS and MDS switches. But I believe it makes sense to have the ability to change the admin allowed vsans on UCS too.
clayguthery
I just started a new deployment on 2.2(5a) and ran into this exact same question! Still hunting..
This is a bit frustrating and confusing.
I'm looking at my old UCS's show vfc command and I can see both vsan1 and vsan3375
vfc876 is trunking (Not all VSANs UP on the trunk)
    Bound interface is port-channel107
    Hardware is Virtual Fibre Channel
    Port WWN is 23:6b:00:2a:xx:xx:xx:xx
    Port mode is TNP
    Port vsan is 3375
    Trunk vsans (admin allowed and active) (1,3375)
    Trunk vsans (up)                       (3375)
    Trunk vsans (initializing)             (1)
Same situation on the new one with the new firmware :
vfc733 is trunking (Not all VSANs UP on the trunk)
    Port WWN is 22:dc:00:2a:xx:xx:xx:xx
    Port mode is TNP
    Port vsan is 1
    Trunk vsans (admin allowed and active) (1,20,3022)
    Trunk vsans (up)                       (3022)
    Trunk vsans (initializing)             (1,20)
I just don't like seeing the other vsans remain in initializing mode for ever.
Limiting the allowed vsans on nexus VFC or FC ports is really easy and can be done by adding switchport trunk allowed vsan xyz , but not sure how to do it on UCS. it seems to me that although we have the configuration option in the old firmware , but it still suffers from the same issue.
Can someone let us know how to  limit the allowed vsans on FCoE ports on UCS ????
Clay;
Did you find anything about this issue ? I've built the service profiles and it shows that the HBA is member of vsan 1 which I do not have presented to UCS from my nexus . As the result the server won't boot.
This is frustrating
Clay;
I opened a case with Cisco today and had a Webex session with them. It was a surprise to Cisco as well that this feature was not there any more.
We are just trying to do a normal vlan pruning on the FCoE vlans. this can be easily done for Ethernet traffic under the LAN tab for DJL2 but the functionality in no longer there for FCoE.
Cisco Engineer told me that he has to go back to the developers to see why this feature was removed and request for enhancement.
Let me know about your findings.
We have been fighting others issues and haven't come back to this one as it's not really a deal breaker for our configuration. Please let me know if they come back with any further information, thanks!
Pom Ham
After 2.2 code, they have removed the vsan drop down menu in UCSM. As long as the port-channel is created, it will have the vsan assigned to the fcoe uplinks. You can verify by running the show command in nxos.
In the example below, we can verify the vlan 111 associated to the vsan 111 under the allowed vlans.
nterface Ethernet1/9
  description C: FcoeUplink
  pinning border
  switchport mode trunk
  switchport trunk allowed vlan 111,300,400,501,510,1010,4048
  udld disable
  channel-group 111 mode active
  no shutdown
#show running-config port-channel 111
